Saltwater - the fuel of the future?
Anyone seen this:
http://www.youtube.com/watch?v=JiKa4nOkHLw
I wonder if the energy balance on this (after subtracting the energy to generate the radio waves) is favorable?
Good luck,
Latexman
RE: Saltwater - the fuel of the future?
It's been a long time since chemistry.
Of course, if there's some strange nuclear process going on and mass reduction, all bets are off.
Good luck,
Latexman
So, what's the big deal? This "invention" was posted on ET about 2 yrs ago, and nothing came of it then.
TTFN
Good luck,
Latexman
TTFN
StoneCold
rmw
Actually, there usually is a "preferred state" for most molecules and the amount of energy that it takes or gives off is dependent on whether the molecule is in its preferred state or going to it.
Water is a very stable compound. To break the chemical/molecular bond between the hydrogen and oxygen requires input of energy (i.e., it's an endothermic reaction.)
On the other hand, free oxygen and hydrogen are rather unstable (which is why you usually see them described as H2 and O2. If present in sufficient concentrations, they are quite willing to join together in an exothermic reaction to create water, with a large release of energy. Ever heard about the Hindenberg?
I haven't watched the U-tube video -- can't access it at work and I had better things to do at home last night. However, if he's proposing to power cars by dissolving the hydrogen/oxygen bond in water -- he's all wet.
Patricia Lougheed
Please see FAQ731-376: Eng-Tips.com Forum Policies: Eng-Tips.com Forum Policies for tips on how to make the best use of the Eng-Tips Forums.
He's using radio frequency waves to liberate H2 and O2 from saltwater. Kind of like electrolysis.
Good luck,
Latexman
TTFN
In the clip, I see a RF generator getting power ( which came from a fuel based power plant, efficiency (e1)) from the wall and using it to get less power to make RF (e2)from burning something (e3) which goes thru a Stirling engine(e4) yielding less mechanical power. All told he would probably be lucky to get 30% efficiency --E=e1*e2*e3*e4.
If he calls the saltwater "fuel" he is dreaming.
I don't think Saudi Arabia is worried about this just yet.
That's what I was getting at. Plus, Homer Simpson is the source of the 'obeying the law' quote and that makes it even funnier.
The problem is fundamentally what I was getting at in my first post. The water is not a fuel. This process creates a fuel from the water (and some would argue that isn't even true, that the hydrogen is merely an energy storage medium, like a battery), but to do that takes energy input, and you can never get out of it what you pump in. Take gasoline, for instance. The sun and earth have made it, and from our viewpoint, there is a net energy gain when we burn it, but when you look at everything it took to create that fuel, there's a lot more energy that went into making it over time than we get out of it, and we don't really think about that.
Aaaanyway, a chemical bond is a chemical bond. We can nitpick about preferred and ground states, but to get it into or out of those states requires energy flowing into or out of the molecule. Since the whole point of a preferred state is that it's the most energetically favorable state for the molecule, it's pretty safe to start from the viewpoint that on average, without a directed input of energy, a bulk material is statistically going to be in its preferred or ground state. Getting a large number of those molecules into non-preferred states should take extra energy, making the process even less energy favorable.
I light of that, the gist of my argument was that a chemical bond represents a certain amount of energy. Since this process is in essence first breaking water into hydrogen and oxygen, then turning them right back into water, the net energy moved is zero. The minutiae of which process is endothermic or exothermic doesn't really matter because we start with water and end with water. Whatever energy moved into or out of the water to create the hydrogen and oxygen should be equal in magnitude and opposite in flow to the energy moving when the gases recombine to reform the water. Viewing just that reaction, there is no energy added to or removed from the system by splitting the water and recreating it. Of course, this reaction is not spontaneous, so take a step back, and you have the input in the form of RF required to kick it off, and then you get the heat and light put off by burning the hydrogen. The energy is coming from the RF forcing the water to do unnatural things.
Now, if the RF generator were powered by a nuclear process, then we could get a net energy gain due to mass reduction in the nuclear reaction.
Otherwise, I don't see how this possibly works.
After all concerns about the 2nd law have been accounted for, IMHO if hydrogen (as a chemical reagent) can be obtained from a 'new' (potential) process cheaper or more efficiently than by conventional electrolysis, it merits attention.
If it were any good , don't you think the oil people would be rushing to buy the patent rights to squelch the idea?
It looks like an expensive torch to me.
To burn water with a flame one can use fluorine.
Saltwater is not the real fuel here- saltwater is not a fuel. Most of these "free energy" scams are fueled by ignorance, compounded by bad measurements.
Even if you were able to split water by some magical electrical or electromagnetic process to produce hydrogen and oxygen with 100% of the maximum possible thermodynamic efficiency, you STILL would be incapable of building a perpetual motion machine much less an over-unity machine. The fuelcell or Stirling engine or whatever else you'd try to use to generate energy from the hydrogen and oxygen has an efficiency significantly lower than unity. And hydrogen as an energy storage medium is only good in respect to the product it generates. It is a real pain in the @ss technically in virtually every other respect.
Thermo in a nutshell: #0- you must play the game- there's no other game in town. #1- you can't win. #2 You can only break even on a VERY cold day. #4- it NEVER gets that cold!
To moltenmetal, you speak about fluorine-in-water, and I refer to water-in-fluorine. From the little I know about fluorine, it can put water aflame since it is a powerful oxidant and highly electronegative, taking oxygen from the -2 to the 0 or +2 state.
The internet tells us, I quote:
"It is so reactive that glass, metals, and even water, as well as other substances, burn with a bright flame in a jet of fluorine gas."
Translating from old Chemistry notes of mine:
"Fluorine has the highest reduction potential of all common chemicals, and it reacts violently at room temperature with almost all other elements. Water burns in fluorine with a weak, luminous flame to give HF and hydrogen. An equimolar reaction of HF and water results in HF + O2. An excess of fluorine can result in oxygen difluoride and HF."
Are these notes wrong?
I agree with your message in all other aspects.
CH5OH: I'm afraid I probably don't understand your post. If a fossil fuel other than coal is used as the energy source, I'm afraid that making a liquid or even liquified gaseous hydrocarbon fuel for transportation purposes is definitely going to win out over using it to make hydrogen, in terms of well-to-wheels energy efficiency. Pure hydrogen generation, transport and storage are all (energetically) lossy, and real fuelcells are not THAT much more efficient than a hybrid IC engine, to say nothing of the comparative cost. Once you've converted your entire electrical grid over to renewables or nuclear, hydrogen might then be worthy of consideration as a transport fuel. Until then, it's a distraction.
