Rust in reinforcing steel
Is there any danger when the steel is rusty right before I pour concrete in columns and beams??
I am working in a project in Panama City, Panama, where the weather is hot and humid, and rains almost every day. It's almost impossible to keep the reinforcing steel rust-free.
Should I worry about the rust???
Nigel M.
Nigel M.
RE: Rust in reinforcing steel
Nigel M.
When I was in school in Texas, I drove my car to the beach and it got damp from coastal fog. After I returned home to Austin, the car continued to rust. I always thought this was caused by salt.
It would be wise to document the condition of the rebar and the composition of the concrete. If the structure falls down in 15 years it would be helpful to know what additives had been used in the concrete.
Photos could be helpful.
roger,(a geologist)
Kemp, Brezny, and Unterspan "Effects of Rust and Scale on tth Bond Charactereistics of Deformed Reinforcing Bars" ACI Journal, Proceedings V.65, No. 9, Sept. 1968, pp. 743-756
The "Commentary on Builiding Code Requirements for Reinforced Concrete" (ACI 318-77) says:
"Research has shown that a normal amount of rust increases bond. Normal rough handling generally removes rust which is loose enough to injure the bond between the concrete and reinforcement."
"How clean must rebar be?" by Bruce Suprenant and Ward Malisch - Concrete Construction June 1998.
From the Concrete Reinforcing Steel Institute (CRSI) Manual of Practice, paragraph 8.2, "Surface Condition of Reinforcement", rust and mill scale OK as long as overall dimensions/properties not affected.
