postprocessed code header removal
Hello
I want to remove the header from postprocessed code, but i dont know if this can be done with postbuilder and how?
This one:
Information listing created by :  Pavilion
Date                           :  22.2.2010 13:40:54
Current work part              :  E:\cnc\S760\test.prt
Node name                      :  pavilion
RE: postprocessed code header removal
This looks like the listing from the information window.
When you post process a file is created.   Open the file that is specified when you select post process and see if it has the header information.
John Joyce
Tata Technologies
1675 Larimer St.
Denver, CO
www.myigetit.com
NX5,6, 7 Solid Works, Solid Edge
OMG yes, this header is only in information window
I cant belive i didnt figure that out. Thanks.
