wheel velocity
wheel velocity
wheel velocity
Assume a vehicle with four independently driven in-wheel motors on slope.
How can I calculate each wheel velocity? By knowing, the vehicle velocity, slope angle and each wheel torque.
thanks,
RE: wheel velocity
Since you have give slope angle and torque as a condition, is there any slippage?
rmw
RE: wheel velocity
I have the vehicle and wheels dimensions and I calculated the normal force acting on each wheel.
 There is a slippage for each wheel on the slope.
(Wheel Traction force – wheel resistance force – wheel mass * g* sine (slope angle))/ Wheel mass= wheel acceleration
So I can find wheel velocity by integration of acceleration.
Is there more to consider?
RE: wheel velocity
I am wondering , why sensors have a difficulty to measure linear velocity online?
 traction force is the result of motor torque.
if you think the question is too easy and don't want to answer it, plz dont write spam.
RE: wheel velocity
"There is a slippage for each wheel on the slope.
So I can find wheel velocity by integration of acceleration."
Really?
I get infinity for the speed of the slippig wheels and you can't get vehicle speed from slipping wheel speed.
This sounds like a ridiculous homework problem. Ask your professor what he thinks the answer should be.
RE: wheel velocity
I want to measure the wheel slippage on the soil.and I knew the vehicle velocity!, I need the each wheel linear velocity.
RE: wheel velocity
I have tried that, haven't got right number! looks very easy but I am struggling with this.
RE: wheel velocity
it is not match with tractive force V.s slip ratio for this particular soil type.
RE: wheel velocity
How do you know you don't have the right number? What have you tried?  What resources have you used to arrive at your answer?
When I check calculations, I frequently ask for the source of any equations used -- so that I can verify that they're being used correctly.  I'd have a hard time with "someone on this free internet site told me that this was the way to calculate wheel velocity." (I'd also question anyone using wikipedia as their source, even if it was correct ...)
Patricia Lougheed
Please see FAQ731-376: Eng-Tips.com Forum Policies: Eng-Tips.com Forum Policies for tips on how to make the best use of the Eng-Tips Forums.
