2" SCHED 80 600 ANSI.Flange
Is it within code to weld a 2" Weldneck flange directly to the top of pipe (nps 8") csa z662-07 Code
RE: 2" SCHED 80 600 ANSI.Flange
No
More Info EuroPipe??
You need a weld-o-let or a branch tee
Like dcasto says,
You need a piece of pipe(weld-in/on)or better a weldolet for a proper weld.
That's not possible with a grinded flange.
Greetings
Take a look at the backside of a 2 inch flange, think there is room to put a welding rod in there when it is up against a pipe?
David
I bet ya that if you look at the "branch table" in the piping spec.s it'll show you'll be using a weld-o-let on a 600# line.
Td Williamson Thread O Ring Flanges are designed for this purpose.
And if You want a short connection try a padflange
