Priciple View Scale
Priciple View Scale
Priciple View Scale
Hi All,
While placing the principle view from the view wizard in draft, I used to be able to scale to suit myself (in V20), by selecting a ratio from a list.
In ST2 MP3 whoops MP2, I do not have that luxury as there is only one ratio to choose from. I have to place the view then scale to suit.
Is there a setting somewhere or is this it!
Cheers
RE: Priciple View Scale
did you copy the Custom.xml over from V20? If so then you're
screwed. The St1/ST2 Custom.xml now holds the draft scales
which the V20 Custom.xml did not have.
BTW: I think you meant the primary view, because the principle
view inherits the scale from the primary (the first placed) view.
dy
Thanks Don,
Primary view, yes.
Custom.xml, yes to that as well, :(
luckily I do have to remove ST due to the errors in MP3, so I'm hoping that this will restore the Custom.xml.
Is there a way of extracting the custom.xml file from the install disk?
Cheers
