Parallel Computing
Parallel Computing
Parallel Computing
     I have installed a parallel computing toolbox in my PC for MATLAB.Does it require a server to effectively run.To be more clear, do I need multiple processors to get maximum efficiency for my toolbox?
RE: Parallel Computing
The first sentence from the product description reads:
"Parallel Computing Toolbox™ lets you solve computationally and data-intensive problems using MATLAB® and Simulink® on multicore and multiprocessor computers."
- Steve
Thank you very much!I have a core 2 duo processor, that is there are 2 processors. I will try to run on it and see what would be the max i can get out of it!
