SAVE AS tries to save parts opened in the session
General NX question..
Why does NX try to save all parts opened in session when I try to do SAVE AS on a Displayed part Iam working on.
Is there a way to stop NX from doing this..
Suggestions
Suggestions
RE: SAVE AS tries to save parts opened in the session
"Good to know you got shoes to wear when you find the floor." - Robert Hunter
Best Regards
Hudson
www.jamb.com.au
Nil Desperandum illegitimi non carborundum
Also could you make sure that you tell us what version you're using next time maybe we can check it out for you.
Best Regards
Hudson
www.jamb.com.au
I opened an assembly and modified a component but did not save it. I then changed one of the other components to be the Displayed Part and performed a 'Save As' operation and while it asked if I also wanted to 'Save' the Assembly, when I hit cancel instead, it performed the 'Save As' on the Displayed Part and ignored all of the other part files, including the one that I had explicitly modified for the test.
So as best I can tell, it's working exactly as was intended to work.
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
Thanks for all the replies..
NX6.0.2.8... We have Structure update on save option turned on ,so that it syncs the PSE ( Teamcenter ) and ANT.. What I was trying to do is, on the displayed part, Do a SAVE AS to make a new rev..
Turning on structure update on save , can it be a issue?
