solidedge v20 smart dimension hole callouts
We have 5 solid edge stations all with the same software. One of the stations for some reason messes up all other draft sheets when using smart dimension on hole callouts. Whenever draft sheets are updated on the other systems it loses all info and all you have is leaders with no text. When this happens we have to go into the model itself and edit the holes, save the model and update the draft sheet and the text comes back. Its mind boggling and and costing us time. Can someone please help....
RE: solidedge v20 smart dimension hole callouts
I guess that those templates use a dimension style with a different name or something.
Copying the templates is a simple solution. You can look at the Hole callout tab in the dimension style.
