How to split a surface?
How do you split a surface (we use Wildfire 2). The need is to apply a different color to one section of a surface and not the remaining part. How can a surface be split using WF 2.0?
Thanks for the help.
SrG.
SrG.
RE: How to split a surface?
Peter Stockhausen
Senior Design Analyst (Checker)
Infotech Aerospace Services
www.infotechpr.net
SrG.
Chris Loughnane - Product Design
http://www.pdnotebook.com
http://www.twitter.com/DesignNotebook
Peter Stockhausen
www.infotechpr.net
Peter Stockhausen
www.infotechpr.net
It's definitely a hack and has no practical utility, but if you are just trying to snap a screenshot to communicate to the client, it will work.
That works very well. Though perhaps not as quick and easy as it can be done in Solidworks. We use WF 2.0. Wouldn't you think that in a later release that function would be available without a "work-around"?
Thanks, SrG.
I can see splitting a surface to get a shutoff for molding, or something similar.
I suppose it really only comes into play with solids, which I avoid.
