Wiring Form 6S Meter As Form 5S
Dear Folks,
Is there a way to wire a Form 6S meter to accommodate Form 5S Meter requirements. The Switchgear instrumention available are 2 PT's and 3 CT's, the PT's are connected A-B & B-C while the three CT's are connected in star configuration. We only have Form 6S meter which if I understand correctly only accepts Phase-Neutral output from the PT's.
Is there a way to wire the instrument CT's and PT's cited above to the Form 6S meter without having to re-configure the bus PT's and connect them Phase-Neutral?
Thanks in advance for your feedback and insight.
RE: Wiring Form 6S Meter As Form 5S
