Hydrocarbons in TEG regeneration unit
I'm working with glycol dehydration units and we have some problems. This TEG absorber units are installed on oil production platforms. I would like to describe one of this units but there are four another unit with the same problems but operating parameters are slightly different. This unit was designed to handle 320mmscfd of gas and product gas should have water content less than 4lb/mmscf(80ppmw or -12 degrees Celcius at pipeline pressure). Design pressure was 58.5barg and temperature was 35 degrees celcius. Gas temperature is controlled by gas cooler which cools gas from 45 degrees to 35 degrees. In purpose to increase oil production all gas hanling system pressure was reduced to 52.5barg. Gas water content is in spec(there are a lot of debate around reliability of moisture analizers but i thnk that tey are OK). Unit operates at design rate but we experienced one problem. Glycol regeneration unit is just ordinar(standart or simple) unit with stripper after reboiler and performance of this unit is OK. It regenerates glycol to design 99.3% of pure glycol. BUT WE HAVE GOT HYDROCARBONS ALL AROUND GLYCOL REGENERATION UNIT. FOAMING IN FLASH DRUM BECAME VERY EXECIVE. I understand pressure reduction decreased contactor and contactor inlet scubber capacitywhich leads to liquid carry over from inlet scubber to contactor and glycol contamination. Also pressure rediction increased amount heavier hydrocarbons in gas. We tried to reduce temperature to 30 degrees but it didnt helped. Can anybody advise what can I do to prevent foaming and glycol contamination.
RE: Hydrocarbons in TEG regeneration unit
The most common problem is where the TEG going to the contactor is cooler than the gas. That's an easy check.
More often I see this situation and one of the best fixes is to have a coalessing filter separator ahead of the glycol contactor and just a few feet away from the contactor. In some cases I even recommend cooling the gas to 30 C go through the separation equipment, then heat the gas to 35 C.
What do you think?
What kind of coalescing filter separator would you advise?Where can i find them? It looks like good idea!
Thanks for your responce. really would like to communicate this issue with more experienced than me person.
I've seen TEG contaminated so badly that upon analysis, it had 15% heavy HC built up in and there was know way to seperate it without vacuum distillation.
You need to remove the liquids before they get to the contactor and keep the gas warmer.
One of our ideas was changing char coal filter more frequenly. But differential pressure across this filters never goes too high.It is within normal operating range specified by vendor. and also lean glycol samples doesnt show big concentration of HC.What is from your opinion or experience "normal" HC concentration in lean glycol. I assume even if char coal filters cant remove HC. then all of them will be evaporated in reboiler.
On our units flow through char coal filter varies from 20% to 25%. I assume this depends on pressure at which contactor is operating. But could you please explain it how to determine flow through char coal filter.
I spoke with several experts and didnt get straight away answer and undersood that this problem is quite common for TEG dehydration units. I really apreciate help if some body can share his/her experience around this problem.
Tarlan
Every so offten the operator went offspec on water, but they lived with it instead of fixing the problem in a fashion similar to what I stated here.
Companies like Perry Equipment (PECO) have field representatives that can measure liquids in a mist phase to prove up what I predict. They and other vendors (qbjohnson, peerless, Porous Media) are all good at helping you with your situation.
I thought that liquid carri over can be measured only with help on radioactive tracers. WE have a lot of nucleonic level transmitters on pltforms. Thats why i was suspesious about liquid measurement in a gas. But I contacted PECO and was surprised. Thanks again.
Tarlan
