NX6 w/TC - What are the Pros and Cons of a separate drawing prt file?
I am currently working on developing the migration path from IdeasNX12w/TC to NX6w/TC. I would like to get a better understanding of some of the technical pros and cons which may effect our process or long term data management strategy.
Separate drawing files: It is my understanding that the only reason to go this way would be if your organization does not formally release part and assembly files...just drawings.
Mike
Mike
RE: NX6 w/TC - What are the Pros and Cons of a separate drawing prt file?
This is what we refer to as the 'Master Model' mode and it's how we do lots of stuff in NX. In addition to Drafting, we also support this mode for Manufacturing and CAE. In fact, with CAE we basically make this the STANDARD way of work by making an automatic behavior. This also helps to keep the Master Part Model as 'clean' as possible, not burdening it with all the Drawing, NC Toolpath, FEM Meshes/Constraints, FEA Results, data which if we didn't use the Master Model approach would all have to be stored inside the SAME Part file.
So I hope you can see that this goes way beyond just Drawings and in fact is a fundamental architectural advantage that NX has and which we intend to continue to enhance and strengthen. So I hope you seriously consider what this might mean is you choose to not go this route, which is possible, but as I hope I've got across to you, is NOT recommended.
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
Another advantage is that is reflects common systems of change management in practical terms. While it is common to revise component drawings for every model change many people and organisations have come to realise that maintaining assembly structures should effectively require that every model change cascades all the way to the top.
The third advantage is that where you have different individuals working on data for industrial design, engineering design, drafting, machining, tooling and FEA then you can work in separate files on the same data even without having write access to some of the files for downstream uses.
Best Regards
Hudson
www.jamb.com.au
Nil Desperandum illegitimi non carborundum
An other advantage : you can used the "reference sets" to control elements that are visible in your drawing, without use the "layer visible in view"...
John R. Baker, P.E.
Industry Sector
Cypress, CA
