Which Rechargeable battery to choose for Meanwell AD-55A
Hello all I'm new with this battery stuff and need some advice on type of battery to choose from.
I need to find a rechargeable battery for MeanWell AD-55A switching power supply.It Should be 12v - 14 v rechargeable battery which has around 2 - 3 AH battery capacity and must be lighter then 1Kg.
I notice all those lead acid types weight more then 1Kg for my requierment and those UPS battery are +1Kg as well. There a lighter battery which I have noticed, example a Laptop battery and those CCTV battery but they are different type of battery technologies.
So there a several type of batteries technology to choose from. Are there all suitable for My Meanwell product? from what I know each technologies requires different type charging methods.
Thanks in advance
RE: Which Rechargeable battery to choose for Meanwell AD-55A
You need to contact the manufacturer.  A battery technology that's incompatible with the charging circuit will most likely be damaged, and might cause ancillary problems.
TTFN
