Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...This site is awesome!...Things I have been trying to figure out for weeks, I got the answer in hours!..."
Geography
tsgrue (Civil/Environmental)
18 Feb 10 19:03
Does anyone have pricing information for geothermal well tests in the southeast coastal plain of North Carolina, South Carolina, and/or Georgia? I'm getting widely different numbers from different sources. This is for a single 400ft well test to determine thermal conductivity, thermal diffusivity, mean temperature, and water level.
Thanks!
tsgrue: site engineering, stormwater
management, landscape design, ecosystem
rehabilitation, mathematical simulation
http://hhwq.blogspot.com
18 Feb 10 19:04
Daggone, you think I could spell 'information'...
thewellguy (Electrical)
25 Feb 10 12:03
The prices will differ depending on the drilling conditions and how busy the drillers are.  Did you specify the hole diameter, pipe type, size, and grout?  What about the clean up after drilling?
You should get a split price one for the drilling, pipe installation, and clean up.  Then a seperate pricr for the test.  All the items you listed above are part of the same test.  Did you specify the lenght of time that the test was to be run?
I work in the midwest and drilling prices here run between $13-$18 dollars per foot.  The agerage cost of a thermal response test is around $5,000.
25 Feb 10 14:11
The most 'reasonable' numbers I've received (in terms of my trust in them), is from $4k to $9k, with $5k being around the most typical. The area is sand generally to 300ft-600ft, rock thereafter - 48hr test.
25 Feb 10 14:48
I would price the drilling at $6,400 and Test at $5,500 for a total of $11,900. so that don't seem so bad to me.
Close Box
Join Eng-Tips® Today!
Join Us             Close
