Dimension Text Commands
When editing dimension text in a drawing there are a number of built in commands. For exampling typing in <DIM> displays the actual dimension. It also seems that <STACK> is a command (though I can't get it to work). Is there a reference that lists all the built in commands and the syntax? I can't seem to find anything in Solidworks help or online.
On a related note, I'm trying to show the formula that drives a particular dimension on the drawing. I would like to show it in the dimension text versus as a separate note. The problem is that I can't get the fractions to stack vertically. I feel like the stack command is what I'm supposed to use but I can't get it to work. I'm on Solidworks 2008 SP 3.1.
Thanks for the help!
-Steris
-Steris
RE: Dimension Text Commands
-handleman, CSWP (The new, easy test)
Thanks a bunch! That worked perfectly. I don't understand why Solidworks would want to keep that information hidden.
