typical compressor specifications
Where can I find typical specifications like horsepower or efficiencies of different type of gas compressors? I am trying to evaluate power and maintenance costs with different type of compressors to help with my selection of a gas compressor.
RE: typical compressor specifications
That is truly a wide open question. When I was researching the same thing for a class I'm teaching in Denver next week, it took a LOT of digging, a LOT of reconciling conflicting claims, and a LOT of nonsense to wade through before I had a table that I beleived.
People use the word "isothermal" when they mean "adiabatic". People use isentropic constants for polytropic machines. People use the word "efficiency" without defining it (and the definitions are all over the map--if you are comparing a recip with clearance to a recip without clearance the "efficiency could be over 95%, if you are comparing power input to work output the number is lower, if you are comparing energy content of input fuel to work out the number is much lower still). People lie.
Maintenance and operating costs are another whole bag of worms. I had a client ask me to look at his flooded screw compressors because they were costing him $20k/month for replacement oil. I operated a fleet of flooded screws 15 times the size of this operation and spent closer to $2k/year on replacement oil. He was operating them without understanding them. So is the number $20k or $2k?
Good luck with this.
David
Centrifugal compressors can range from 60% to 75+% polytropic efficency. The approximate valiue is a function of each manufacturers actual design and you won't the exact value without a RFQ. But generally, the smaller and m ore off theshelf (no custom impellars) run around 68%. Larger custom machines will be closer to 75%. This is the values I use in the simulators to get the rough idea. One of the larger yet noncustom impellar compressors use to let you have their DOS program that gave better eff values. But you are at the mercy of most of the vendors I know.
recips. Recips are a little different. I use polytropic eff in modeling because the thermo efficency is a function of the not only ther estimated approach to isentropis, but adjustments for valve losses and other mechanical losses. Here, the assumed polytropic eff runs between 75% to 85%. For higher speed compressors with high mole weights I assume 76% and for low compression ratio low gravity gases I use .81%. Then I use different vendors programs to get the exact value, well they don't calculate eff, but you get the required Horsepower and then i tweak the polytropic eff in the model to get a matching HP. The crosss check is the discharge temp, this should also match.
With screws, its similar to recips. the range is 40% to 70%. the wide spread is a function of compression ratios. Compression ratios of 8 will have a 40% and with a ration of 2, the eff is closer to 70%. Again, you run the manufactures program that give the HP required. You can adjust the models. The last screw run I saw had adiabatic eff listed.
Maintenance is a little more difficult. maintenance philosophies can creat wild swings. Size of units, number on location... A mid range might look like this
$/HP-yr
cent 100
screw 120
Recip 150
all with engine drivers
no driver
cent 15
screw 20
Recip 30
I've seen way more and way less.
What is there to calculate other than life cycle costs?
maintainance costs, fuel usage, oil usage, etc.
elec. driver is similar
compressor depend a lot on what you are compressing as to the costs associated
But if the loads/conditions varely, the reciprocating compressors may have an advantage as they can be adjusted with pockets and/or driver speeds to meet the changing conditions.
http://www.liberalgasinstitute.com/
or papers on the subject can be purchased here
http://www.gpaglobal.org/doclib/
