led to M12
led to M12
I am using the output of Turck module to power a LED indicator. the output module has an M12 - 3 pin receptacle. I would normally run a single ended cordset assembly from the module and into a water tight enclore. Then i would solder the leads to the LED ass'y. For this application I can not use an enclosure. This means that the LED and it's connection will be in the open. Is there an adapter or cordset that will allow me to connect the output module to a standard LED indicator ass'y?
RE: led to M12
Keith Cress
RE: led to M12
http://ww
Then a cap, for protection.
Probably look ugly. It's a place to start
