SW 2010 - finetuning tips
Hello.
Any of you out there have any finetuning tips that directly apply to SW 2010? I recently upgraded from '09 to '10 and experiencing some performance problems. One issue is that when I go to modify a part in an assembly and go to sketch mode, the cursor jumps around and the CPU usage maximizes out. Even creating a new part in sketch mode I have the same problem. Short of re-installing I could use any advise.
Thanks!!!
SW 2010
XP SP 2
Dell 380
nVidia FX1400
Thanks!!!
SW 2010
XP SP 2
Dell 380
nVidia FX1400
RE: SW 2010 - finetuning tips
"Art without engineering is dreaming; Engineering without art is calculating."
Have you read FAQ731-376: Eng-Tips.com Forum Policies to make the best use of these Forums?
I'm still stuck.
thanks.
Uninstall the video driver, reboot, install the driver listed for the Dell 380 FX1400, reboot.
all suggestions greatly appreciated. i had, as suggested, updated to the latest video driver when I had upgraded. I had also uninstalled and reinstalled the drivers. i did find the problem: it was the settings in the nVidia control panel. i had assumed (assumption is the root of all evil) that the settings would remain the same when upgrading the drivers. i made a note of this for the next upgrade. thanks again for your input and continued success!!!
