Undo not available
Undo not available
I'm running SW01+ SP0 and often find that undo is not available.
This is a major bummer.
Is this a frequent experience in SW01+ or do I just need to upgrade the SP?
Thanking you am I
rokahn1 at yahoo dut com
Thanking you am I
RE: Undo not available
The Undo feature goes back at least 10! If you have done that much, or if you have done any rebuilding (clicking the green light) while making changes then your changes or the Undo button doesn't show anything cause by clicking the Rebuild you are verifying that everything is fine. So SW erases your newest additions......So don't click the Rebuild Icon till your sure.
I don't necessarily think this is the right way to do it, but don't click it....I work like this all the time.
Scott Baugh, CSWP
credence69@REMOVEhotmail.com
http://www.3dmca.com
http://home.insightbb.com/~scott.baugh/
-edit a sketch in a component of an ass'y, causing mate and rebuild errors thru-out the model: No Undo
-suppress a mate with similar effects: No Undo
Is this a setting that can be changed, or a basic limitation of SWX (I'm running 2003 sp0)?
Very frustrating, because manually undoing the edit, i.e. return the dim that was changed in a sketch to its original value, doesn't fix the problem. I end up resorting to "power undo" (exit without saving, then re-open the assy).
BBJT CSWP
Normally I select preview when I'm performing a mate. This is very usefull when the assemblies are getting more complex. If something goes wrong (like overdefining or an unpredicted behaviour) I just select the red X (which is like doing an undo) and the assembly returns to previous state, or I can change the mate definition and preview it until I get what I want. If I have the intended result, I just proceed by selecting the green V. That's one more click in the process, but sometimes it's very usefull.
Crashj 'save early, save often' Johnson
The undo button wasn't even highlighted to select. Also, manually going back and changing the dimension to the original value didn't correct the error.
I had to exit the program without saving to return to the original state. My department has found this practice invaluable and refers to it as "Power-undo".
While we are on the subject, has anyone ever seen the "Redo" button highlighted for selection? I haven't.
Everybody here wants it.... why are they opposed to providing something that works?
