NX6 customer defaults
Is there a way of getting a hard copy of the customer defaults that are set in NX?
I want to change some things, so I would like to mark up a hard copy and give it to the person who can change them.
RE: NX6 customer defaults
Remeber that the customer defaults have Default Levels, you can adapt them in the first screen.
Hope it helped.
Best regards,
Michäël.
NX4.0.4.2 MP10 / TCE 9.1.3.8_build_0711 / NX6.0.2.8 / NX7.0.0.9
Belgium
The spreadsheet has 11,086 lines.
I never imagined that there are so many settings in there.
In the...
File -> Options -> Assembly Load Options...
...dialog at the very bottom you can save your changes either to a file which you can later use instead of the default, or you can make your changes the new default.
As for the variable, you can set...
UGII_LOAD_OPTIONS=...
...to whatever load option file (.def) that you wish to use (this file, by definition, is then the 'default').
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
A tip on this post : if you want to generalize a config of "customer defaults" on other computer.
For NX4
Copy : "nx4_user.dpv" that is situated on "C:\Documents and Settings\your_computer_name\Local Settings\Application Data\Unigraphics Solutions\NX4"
Paste it on the other computers
