'Hollowed' out Assembly
Is there an 'easy' way to hollow out an assembly - showing only the baseline dimensions without having to individually create hollowed-out lightweight configurations of each part that goes in the assembly?
(I don't believe so - but it sure would make my life easier this morning.)
RE: 'Hollowed' out Assembly
Save As> Part> Exterior Faces.
"Art without engineering is dreaming; Engineering without art is calculating."
Have you read FAQ731-376: Eng-Tips.com Forum Policies to make the best use of these Forums?
