Compliance plate
Compliance plate
Compliance plate
Hi members,
what elect info goes on a compliance plate. Can anyone advise me?
Thanks in advance...
RE: Compliance plate
Hi engsatapex
You might get a response when you let members know what sort of elec equipment your talking about, as my cyrstal ball is in for service at the moment.
desertfox
As the fox implied, that info is defined in the standards that you designed your product to meet.  Thus there are a lot of variations - consumer equipment, industrial, hazardous locations, UL, CE...
John D
The Canadian Electrical Code specifies this for some equipment. I expect that the NEC may also specify the information to be included.
Basic is Voltage and Amperage. Most applications require frequency also. From there check your code for specific information.
Examples;
RPM is required for most motors but not for transformers.
%imp V is required for many transformers but not for motors.
Bill
"Why not the best?"
Jimmy Carter
