Repair of steel pipline inside slab
Anyone out there have knowledge of how to fix a steel pipeline encased in a post-tensioned concrete slab?
The pipeline is 3" steel, welded joints, with one 90º bend. It carries hydraulic fluid at 200 psig for an elevator. The pipe is in a post-tensioned concrete slab in an outdoor parking structure. Location is subject to ambient temperatures as low as -30ºF.
The effected elevator is one of two, ech with a seperate hydraulic power unit and piping. One elevator's pipeline has a leak causing that elevator to be non-functional. Fluid can be observed oozing up from a crack in the slab. The crack may have allowed water and de-icing salt to corrode the pipe. Jack-hammering the slab to expose the leak could cause the other parallel line to start leaking, as it is likely also corroding. Having both elevators down would be a major problem.
The elevator code official will not allow a hose to be run within the pipe. Above-slab piping is possible but cost-prohibitive, as the code official requires insulating and heat-tracing the piping, along with controls changes to periodically operate the elevator to circulate fluid.
Any help is appreciated.
RE: Repair of steel pipline inside slab
Richard A. Cornelius, P.E.
WWW.amlinereast.com
Essentially doing it twice but you don't have a lot of options.
StoneCold
"The problem isn't working out the equation,
its finding the answer to the real question." BigInch
http://virtualpipeline.spaces.live.com/
