"Laser" cutting font on sheet metal
3
I am trying to extrude font to form a cut-out in a flat part. Typically a laser cutter will cut out the font - I did it once and can't get the same result now - don't want big holes where missing text pieces "fall out" because there is no rib holding them to the parent part.
I have the lettering which I used to generate the attached jpg font - it was Tahoma using an extrude cut - but there was a trick to it - an option to engrave or cut or something which produces the lettering in the jpg.
If one flattens regular text extruded on a sheet metal e.g. the "O" is a contiguous hollow - the centre correctly falls away.
Any ideas?
Link to example .jpg if it does not follow this post:
http://files.engineering.com/getfile.aspx?folder=98d3136d-a5c8-409d-a583-c8b752bf32be&file=PUNCHED_FONT.jpg
RE: "Laser" cutting font on sheet metal
If you don't want the centre of the 'O' to fall out then cut our your text on the flat pattern, not on the folded part.
Search for Stencil fonts on net. Most of them are free. My favourite one is DIN Schablonierschrift. Plain and readable.
EngAddict triggered the word "stencil" which I couldn't think of at the time so I have done what pakl suggested.
Ahh, so you were only after the font? There is a font called stencil in Inventor, is it not suitable?
I thought I had done it a different way but the word stencil made sense. I went throught every font in the list on my PC and none of them were "stencil" fonts - so no, my PC / Inventor don't have a font called stencil - unless there is some way to load one/it?
That is REALLY helpful EngAddict! Tx!
Been through all the fonts on my laptop and don't have that one! My CAD machine is a x64 bit XP so am not sure where I got the one that I used - did recently (a few weeks ago) re-format my drive and re-load all the software (it's a microsoft thing!) so perhaps I was clever last time around and simply forgot!
Anyway, this font is exactly what I'm looking for! (It has a microsoft tag so it's obviously a standard one with some application)
Its going on both machines now.
Cheers
You're welcome.
