Lightweight Question
Hello All,
I have a large assy (about 60MB) that I want to open completely as Lightweight and have selected the options to do that.  However, when it it done opening I see that it is still resolving some of the sub assemblies.  Is there something that I am missing here?  If I open a few of the sub assemblies by themselves the do open 100% lightweight but the top level assy does not.
BB
SW09 sp4.1
XP Pro x64
PDMWorks Enterprise 2009
RE: Lightweight Question
I am not positive on this, but in System Option/Performance underneath the "Automatically Load Components Lightweight" it sounds like you may have the "Always Resolve Sub-Assemblies" checked, and maybe it should'nt be?
Aaron
SolidWorks (x64)/PDMWorks 09 3.0
CADKey 99 R1.0 (Yes, still using it!)
Overworked1 - Thanks for your input, however, I did check that out and the option is "unchecked"
Etron - Thanks for your input but I need to open the entire assembly and as I go from one sub-assy to the next, resolving them as I go.
One thing I did notice is that each sub-assy that opens "resolved" is either a "flexible" assy or it has a "flexible sub-assy" inside of it.  Does anyone know if that is a rule of some sort, that flexible sub assy can not be made lightweight?
I just pulled this from the solidworks.com "knowledge base"...
Question: Can a flexible sub assembly be loaded lightweight?
Answer: No, a flexible sub assembly is always loaded as resolved.
Aaron
Hi Aaron,
Thanks for the confirmation, much appreciated.  I see you are a fellow CADKEY user, my sympathies :)  I started using it when it was Cadkey 97'.....I still have nightmares about that software.
BB
