Setting dimension preferences.
One thing that really annoys me about nx6 is that for every radius and diameter dimension I have to manually edit the style to make the text horizontal and manually placed.
I've look at the preferences, but they seem to apply to all dimensions.
Is there any way to set the preferences so that radius and diameter dimensions can have horizontal text, and all other dimensions have aligned text?
There are countless other things that I think are highly illogical, overly time consuming or badly thought out in nx/unigraphics, but I'll go through them another time.
RE: Setting dimension preferences.
This is the first thing I check when using a new version.
If you don't have the necessary permissions to edit and save to the Site Default Level, have someone who does make the changes for you.
There is much to go through, but I am confident that you will find what you are looking for if you try hard enough.
"Good to know you got shoes to wear when you find the floor." - Robert Hunter
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
7.1.4 Dimensioning circles
It shows a small diameter circle with a diameter dimension on it. The dimension text is on a leader, with horizontal text.
Is it possible to configure NX so that hole notes obtain all of the hole information and display it?
For example, with a cbore hole, can it automatically generate a heard with the cbore information in it?
Can a threaded hole be dimensioned so that the thread pitch is automatically added to the hole note?
see page 36 of this: http://w
I want a dimension like the left hand example in 2.5.3.3
Ben Loosli
That being said, you already have the ability to make your drawings appear as you want them to (manually edit the radius/diameter dims), so there is NO lack of 'ability' to perform, but rather only one of 'ease' of performing. Therefore, if you wish to contact GTAC and have them open an ER, asking that this be made easier to do by adding a separate formating option for radial/diameter dimensions than from linear dimensions, that seems like a reasonable request. Of course, the out-of-the-box defaults won't change, but you could have more 'flexibility' in defining your own, albeit, non-standard 'standard' for your usage (which of course you can do now, except that we don't provide the level of 'granularity' that's needed in this particular situation).
John R. Baker, P.E.
Industry Sector
Cypress, CA
Best Regards
Hudson
www.jamb.com.au
Nil Desperandum illegitimi non carborundum
As a user, anything that involves multiple clicks to do something that you 'believe' is a regular and common task creates a feeling of annoyance and frustration. This assumes that what you thin is regular and common really is.
What is GTAC and ER?
In Mechancial Desktop (Autocad 3D modelling, now replaced by Inventor) you could set dimension preferences overrides for every type of dimension if you wanted to.
I would say that the latest drafting package in NX is pretty good with respect to aligning, moving and snapping.
But every time I do a drawing I end having to manually change the preferences on various holes/small diameters.
Is there any way to make hole notes pick up the data for the hole? In the past I have added parameter links through to the model, and that worked alright, but I'm surprised that there's no set of templates that will automatically add the thread pitch for example.
Yes there is. Once you have you Drawing views placed, go to...
Insert -> Feature Parameters...
...and 'navigator' like dialog will come up showing the structure of your drawing and you should see a node for your part and under it an item labeled 'FEATURES'. Expand that item and you will see all of the features which have parameters which can be inherited automatically onto the drawing. These generally include any Sketches and Holes that are in you part model. You can select as many as you wish to apply at once and then when you get to the next step is asks which drawing view that you wish to place the dimensions in. Again, you can select as many views as you wish, including Isometric views, and finally hit OK and the 'Feature' dimensions will have been added to your drawing sheet.
Note that this works in both Master Model and non-Master Model mode.
Anyway, give it a try and see if this is what you were looking for.
BTW, if you set up your Drawing Templates correctly, you can make this happen automatically as you create you Drawings.
John R. Baker, P.E.
Industry Sector
Cypress, CA
GTAC is our Global Technical Access Center. If you're in the US or Canada you can contact them direct at our 800 number:
1-800-955-0000
Or you can use the regular number:
1-714-952-5444
If you're not located in the US or Canada you should contact either you local Siemens PLM office or if you purchased NX from a distributor, start there.
Or you can try using our on-line services, which you can access while inside of NX by going to...
Help -> Online Technical Support ->
...where you will find a number of options which will give you many different ways of contacting GTAC or leveraging their services and tools, including opening an ER.
And speaking of ER's, that stands for Enhancement Request, which should be self-explanatory.
Sorry I missed this on my last reply.
John R. Baker, P.E.
Industry Sector
Cypress, CA
What I imagined was:
have a dimension called "hole note"
click on a hole
have an option for a range of templates
eg: M[nominal diameter] x [pitch] x * [thread length] depth full thread
or
M[nominal diameter] x [pitch] THRU
click on the type wanted
place the leader
At the moment I have to:
place a diameter dimension
edit the style to make it horizontal and manually placed
edit the tolerance to 0 precisions
change the diameter symbol to user defined, M
That then puts a dimension saying M4 for example.
I then manually edit the text to add the pitch
and any depth notes
John R. Baker, P.E.
Industry Sector
Cypress, CA
Would it make sense for radii to automatically snap to the non-material side of the part. ie outside of the model???
(ps how do you quote on here!?!?)
http://www.tipmaster.com/includes/tgmlinfo.cfm?
There you will find all the various formatting information.
John R. Baker, P.E.
Industry Sector
Cypress, CA
You type
[ q u o t e] blah blah blah help [ / q u o t e]
Are you suggesting that I use the text editor, click on "Relationships", click on "Expression" icon, and then pick the relevant parameter from the list?
"M4 x 0.7".
In the specification drawing file I've edited some text and added "relationships", "expression", linked to the actual part. However, the list does not show p104. So I added another expression and then manually edited the resulting code so it uses p104. It now shows the tapped hole diameter and pitch, which is good.
However it involved far too much faff to be considered efficient, and I don't understand why p104 was not showing as an available expression.
