Choke Failure/Collapse
Hei,
For well flowlines,if choke collapses there will be an overpressure downstream the choke.I would like to know how many choke failure we have to consider at a time (may be one/two) and which standard refers regarding choke collapse requirement.
Appreciate your respose.
UKD
UKD
RE: Choke Failure/Collapse
the monitor doesn't have to be a choke (a globe valve) it can be a fail close valve like a gate or ball valve with it's own control loop.
