Tractive effort requirements
Has anybody got the calculation method for determining the tractive effort required to counter-rotate a tracked machine on various surfaces with varying track length and track pitch?
Thanks...
RE: Tractive effort requirements
by counter rotate do you mean as in rotate about the centre of the vehicle (like a tank, with tracks moving in opposite directions to do a 360 spin).
If so then i think the best way to look at it would be to take a force couple, modeling the vehicle as a circle with tangental force components.
You would need to set a target rotational speed (omega [rad/s])
Its probably best to treat it like a spinning disc and calculate the torque by T=I.alpha
where T=torque, I = moment of inertia (need to also calculate this, different formulas for different shapes), alpha=angular acceleration (calulate by differentiating angular velocity (omega) wrt time).
Would be interested to see what others think...
This would be a very complicated calculation. Obviously the location of the center of gravity comes into play; but so does how level the ground is, and the exact tread design, etc.
Unless you are trying to optimize the design of a particular machine, I would look at other machines of similar size, weight and usage. On some machines the engine HP is more determined by not getting stuck in the mud than anything else.
I know it's not a very good answer, but if you want more help you need to provide more details.
ISZ
