simple shape design, help
Hello All,
First time post looking for some help. I need to build attached shapes. Lofting from a square base to a circular area doesn't do quite the right trick, I am looking for a parabolic curve instead of just a straight loft from base to base. Ideas?
RE: simple shape design, help
2. Revolved cut with parabola shape.
-handleman, CSWP (The new, easy test)
See also FAQ559-1100: How Can I Show An Image In A Post
1. Bottom rectangle
2. smaller rectangle
3. Circle
4. Point
Finish it with a fillet.
~ BT
Use parabolic guidecurves on the loft. I hope this helps.
Rob Stupplebeen
http://www.EsoxRepublic.com-SolidWorks API VB programming help
