Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...I have found your site brilliant. What makes it good are the people that contribute to the site..."
Geography
pipeneer (Petroleum)
16 Feb 10 15:34
I am installing a 6"-900#,BW,FLEXIBLE paralell wedge GATE valve, my questions is while PWH treating of the two BW at the ends of the valve, should we close the wedge completely or let them stay open, my guess is fully closed but any secound opinion would be greatly appreciated.
For what it's worth, valve's material is A182 F11,DP 130 bar and DT 160 Deg.C.
Helpful Member!  metengr (Materials)
19 Feb 10 20:59
Check with the valve supplier first. If they cannot supply an answer, I would leave the wedge open. The wedge and valve body are different masses and thus will heat up at different rates from externally applied heat. The wedge being a smaller mass will heat up faster and could put increased thermal stress on the valve body in a fully closed position and crack the seat if it has hard facing. How do I know this? I learned it the hard way years ago.
21 Feb 10 12:43
Thnxs metengr, I'll contact the manufacturer, and believe even your point is valid, if they have componsated for the forces that you mentioned,then keeping the gate closed ! at least mitigates distorsions alot.
Mr168 (Materials)
22 Feb 10 11:13
More often than not, these requirements will be right there in the O&M manual.  Typically when I see them specified in the closed condition, it's a combination of preventing weld spatter from damaging the seat (never an issue, as we use GTAW on all root passes) and distortion control.
Close Box
Join Eng-Tips® Today!
Join Us             Close
