API 650 Design Wind Pressure
There appears to be a discrepancy in the design wind pressure for API 650 tanks.
-Section 5.2.1 defines the wind pressure on vertical surfaces to be 0.86(V/190)^2 or 18(V/120)^2 which is used in the wind overturning (Section 5.11) and Appendix F calculations.
-When calculating the stiffener requirements for wind (Section 5.9.7) and for external pressure in App V, it indicates that the wind design pressure is 1.48(V/190)^2 or 31(V/120)^2
Can anyone explain why two different wind pressures are used? Thanks.
RE: API 650 Design Wind Pressure
