Magnetic Bar stock
Magnetic Bar stock
Greetings. Working on a linear type solenoid. Have identified internal core component to be low carbon <.05, Mn .22 P, .011... HRB 27-37. Material identifes as AISI 1005, 1006. I am having trouble locating bar stock to make prototype samples, and to secure a production source. Does anyone have a source? or might reccomend an alternate more commercially available material? We have had some luck with 12L14, but variations in carbon up to .15 may give is some performance issues. Any input would be appreciated.
Scott
Scott
RE: Magnetic Bar stock
You don't say what diameter bars you are looking for. These specialty steels are generally only available in small sizes.
B(T) H(A/m)
0.000 0
0.005 9
0.011 15
0.022 24
0.042 35
0.081 48
0.153 63
0.299 85
0.416 97
0.520 110
0.624 125
0.715 141
0.805 158
0.925 186
1.006 210
1.105 246
1.211 300
1.301 367
1.407 505
1.502 782
1.601 1740
1.700 4368
1.801 8629
1.904 14520
1.949 17730
1.998 21670
2.047 26480
Ill plug this into our FEA software and see what i get.
I have been able to find some 1002 Bar stock which i am having delivered. The electrical iron was outrageously priced, and is far too costly for our design. What materials are you using in place of the 1005 that you used to employ?
Best regards,
Scott
Scott
Scott
