Thought that I mastered Excel...
My spreadsheets are usually small and easily handled. Copying a cell down a column is quick and easy, just mark the cell, put cursor on lower right corner and drag down. Nothing to it.
But, I now have what I thought impossible in Excel, a sheet with 12 columns and 195729 rows of data. The 'drag corner down the column' method is very awkward. And I cannot find any other way to do it. Surely, there is another way - but how?
Signed
Tired index finger
Gunnar Englund
www.gke.org
RE: Thought that I mastered Excel...
If you want to select a continuous block of data:
Hold down shift.
end - down  (press and release end key, then press down arraow key)
end - right  (press and release end key, then press right arrow key)
Let me add a step in bold
Place cursor in upper left hand corner of the block of data
Hold down shift.
Another possibility (depending on what you're trying to do).
Ctrl-A
The first column you just gotta do; but once you rows 1-195729 in column A, you can write a formula in B1 and then with B1 highlighted, double click on the lower right corner of B1 and it will fill itself in to the last row of column A.
I misread the question. My previous responses were for selecting a range. I see now you are looking to copy down a cell. I haven't tried David's approach.
What I usually do is copy down the first column as David said. Then navigate to bottom of the first column (end-down).  Then place an X in that bottom row continuing accross as many columns as I think I'll need.  Then when I want to copy, I use end-down to get the relevant portion of the column.
Thanks! Was AFKB for a while. Will have a go on it. Isn't Eng-Tips just good?  smile
Gunnar Englund
www.gke.org
Here's the other way:
Suppose you want to copy formulas in cells D1:H1 down all way to D195729:H195729.
1. Select range D1:H1 and copy it (ctrl C).
2. Press function key F5 (goto)
3. In reference window type: H195729
4. While pressing Shift key click Ok button. The Range D195729:H195729 will be selected.
5. Press Ctrl-V (or edit/paste) to paste the formulas into selected range.
control arrow takes you in that direction to the end of data, if the first cell has data in it, or the last blank cell before data if it is empty.
So a typical sequence is
ctrl c
ctrl shift down
enter
which copies the first cell in a column all the way down to the end of contiguous data.
Cheers
Greg Locock
New here? Try reading these, they might help FAQ731-376: Eng-Tips.com Forum Policies  http://eng-tips.com/market.cfm?
Thanks a lot. Of the methods shown, I think that the one proposed by davidbeach is absolutely superior. If you haven't tried it, here is how it works:
Put something into the first box in the column that you want to copy all the way down to end of spreadsheet. Double-click lower right corner. Magic!
Thanks.
Gunnar Englund
www.gke.org
Works for me in Excel 2003.  Look for the cursor to turn into a thin "plus" sign indicates cursor is in the right position.
electricpete's method works for me on the sheet he provided. And I'm using Excel 97...
-- MechEng2005
I wouldn't worry too much about mastery; most people probably use less than 10% of the total capabilities of Excel.
TTFN
MechEng - my spreadsheet, but David's suggested method.
I agree there are a lot of things hidden within excel.  Who'd of thunk you can double click on the corner of a cell. Or hit "shift" while pressing ok to a dialogue box.
You can use this for basic series in the first column too:
Home-fill-series... (at the end of the ribbon).
enter columns, and the increment, and 'to' 195729.
Then do the double click thing in the next column on your first cell formula.
PS. did you really need this many rows, or just wanted to enjoy the new real estate in Excel 2007?
Yes Kiwi, I needed it.
Am doing a test on kWh-meters and have sampled U and I in all three phases, then also recorded the metering pulse. Sampling rate is 3300 Sa/s on each channel and time is 1 minute. I am now letting Excel calculate instantaneous power and accumulated power and compare to the metering pulses.
It seems that the kWh meter does funny things when power is cycled on/off with short intervals during this minute. Can have as much as 15 percent error  - too much, most of the customers think.
I was thinking of using Matlab, but decided to test Excel. Really surprised to see that there is room for all these data.
Gunnar Englund
www.gke.org
2007 brought the ribbon, a 1048576 row x 16224 column playing field (annoyingly just shy of 30 sec samples over a year) and the awesomely more compact open office XML file format.
FWIW, around here we use a program called Origin instead of Excel when we are processing that much data.  We do that often.
John D
I have to stick with something that my customer has available. So I am limited to Excel and Matlab. Open Office wold probably work just as well. But this particular customer doesn't think it is any good if it doesn't cost.
Gunnar Englund
www.gke.org
If you need more than 64,000 rows Open Office won't do it (not without fiddling with the source code and re-compiling anyway).
Doug Jenkins
Interactive Design Services
http://newtonexcelbach.wordpress.com/
Purely out of curiosity, does the latest Excel allow scales for each data series?
JMW
www.ViscoAnalyser.com
I was going to suggest Matlab; I really liked it for large swaths of data back when I didn't have to pay for the software.
Hg
Eng-Tips policies:  FAQ731-376: Eng-Tips.com Forum Policies
jmw - I'm not sure what you mean.  You can plot selected data sets on a secondary Y axis, and also use a secondary X axis (but only if you have already selected a secondary Y axis).
The procedure is far from obvious, but it's reasonably well described in the help.
http://office.microsoft.com/en-au/excel/HP012341651033.aspx#SecondaryVerticalAxis
If that isn't what you meant, please let us know.
Doug Jenkins
HgTX - try Octave. Stable, free, very matlab like. It isn't quite as fast and lacks alot of the add-ons and toolboxes, but for basic number crunching it is fine. I develop most of my data handling and fft analysis at home using octave and then take it in to work and run it in matlab.
Cheers
Greg Locock
I assume that jmw was asking about 5 different scales for 5 different data series.  Certain programs can do that; Excel is not one of them.
TTFN
IRstuff - I'm sure it could be done in Excel (with a bit of time and effort), but I'm not sure why you'd want to.
Doug Jenkins
Attached is an excel file I created to "work around" the limitation on scales.
Each plot can be "normalized" by dividing by a scale factor (row 29).  The scale factor is displayed in the legend.  The plot goes from –1 to 1 for all variables
There is also some features built in for easy browsing of a large pile of data... time axis can be changed easily by typing in the green cells "tmin" and "tmax".
http://home.comcast.net/~electricpete/eng-tips/PlotInteractiveRev4.xls
