Location Settings for Parts list etc.
Hello all,
By default the Draftlist.txt file is stored locally, but is it possible to point to a network location for this file and settings for weld symbols etc ?
bc.
2.4GHz Core2 Quad, 4GB RAM,
Quadro FX4600.
Where would we be without sat-nav?
RE: Location Settings for Parts list etc.
Hi beachcomber,
Yes ST2 allows this. The Options > File locations dialogue allows you to set the location of the Reports folder that contains the Draftlist.txt file as well as a few other setup files.
Hope that helps.
Jon
Jon Sutcliffe / Solid Mastermind
The Solid Edge Community. Video training sessions, best practice documents, process maps and interactive training http://www.SolidMastermind.com
Thanks Jon,
Unfortunately we are still on ST1, so I assume it's still fixed to local.
bc.
Quadro FX4600.
BC,
you can do it in ST1 (and lower versions) as well but your have
to modify the registry key:
HKEY_LOCAL_MACHINE\SOFTWARE\Unigraphics Solutions\Solid Edge\Version 100\TemplatePath
to point to a new location. Besides that you have to replicate the
folder's structure and contents at the new location. That is
..\Template\More
           \Quicksheet
           \Reports
   all templates
One word of warning: running MakeVerCurr.exe will reset the above key
back to the installation default
dy
Good call dy,
Always a good registry hack hidden away there to sort things out.
One to remember.
Jon
