hepa filter test
hepa filter test
hepa filter test
Hello everybody, first of all i´m from spain and i´m sorry if my english isn´t very well, i hope you understand me.
I want to do an integrity test in HEPA filters with a particle counter in a laminar flow and biological safety cabinets. Looking the UNE 14644-3 (it is the same as ISO 14644-3 but here in Spain), in the section B.6.3, it explains how to do it, but i don´t undertand some section. In section B.6.3.6.2 it says that i have to calculate the standard leak penetration (PL) with the equation: PL = K x Ps, and I have to choose "K" from a table in function of Ps (Maximum allowable penetration). The table shows different values of Ps and the "K" you have to choose, and the minimum value to "Ps" is 5x10-4 and "K" is 10, that i think it belongs to HEPA filter U15 (in this case i think it´s called ULPA filter). My problem is that in the HEPA filters H14, Ps is 5x10-3 and i don´t know which value of "K" i have to choose.
I know that I can use a photometer but I want to do the test with an airborne particle counter, if someone knows how to do it I would thank if he/she tells my the procedure or some webpage I can consult.
Please help me!! I´m very desperate!!! I really hope you have understood me.
Thank you very much!!!!
