isolation valves for anhydrous ammonia pipeline
Is there such thing as a "typical" isolation valve for anhydrous ammonia pipe (say, 8" carbon steel) for plant piping vs cross-country pipeline?
RE: isolation valves for anhydrous ammonia pipeline
You could use the same basic design for both, but you may need extended stems and lube and drain fittings, to order the valve with weld ends and mfgr welded 18" pups, a locking device and maybe an epoxy external coating for the pipeline valves.  Plant valves are more commonly flanged in lieu of weld ends and are usually accessable, so not requiring the extended fittings.
"The problem isn't working out the equation,
its finding the answer to the real question." BigInch
http://virtualpipeline.spaces.live.com/
