close and reopen part NX6
I've read the docs and found in close/close and reopen part some nice options. I start to use them - but I think it doesn't work like the docs says. I've opened an assy and try to use the open as option, but the dialog doesn't work for me.
The file window is empty - can somebody give me advice how to?
thx in ad
thx in ad
RE: close and reopen part NX6
Best Regards
Hudson
www.jamb.com.au
Nil Desperandum illegitimi non carborundum
File -> Close -> Reopen Selected Parts...
...if you look at the tool tip it explains that this allows you to Reopen 'Modified' parts. All the 'Open As' option does is allows you to replace the modified part with a different part, as opposed to simply replacing it with the last saved, or 'unmodified', version of the same part.
If your intentions were to simply replace any arbitrary part, the recommended approach is to select the desired component, either from the screen or the Assembly Navigator, press MB3 and select the 'Replace Component...' option.
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
