Masonry Question
Masonry Question
Masonry Question
Folks,
The allowable flexural tensile stress values are given in the code in Table 2.2.3.2. I am having a hard time understanding when the stress value should be used for stress parallel to bed joint.
An out-of-plane load will produce tension on the inside/face shell and the direction will be normal to the bed joint
An in-plane load will produce a force normal the bed joint on the inside and outside face shell on the tensile side of the N.A.
When will a force produce a flexural tensile stress parallel to the bed joint (normal to head joint)?
RE: Masonry Question
Is it for a masonry wall spanning horizontally?
Yes, I believe that's the only way that can be achieved.  Interestingly, if the wall spans horizontally, you have never a full section of mortar joints only like you do when the wall spans vertically.
Unless the wall is stack jointed.
With the proper block, you can lay it in true running bond and still have full mortar bedding. Not available at all block producers. It has 2 webs instead of 3 spaced at 8" inches on center. You get perfectly aligned webs and cores in either running or stack bond. Works great for  reinforcement and grouting only one cell - grout placement and consolidation are also much easier and better. Also no grout bridging.
Dick
Engineer and international traveler interested in construction techniques, problems and proper design.
