Vibrating rectangular membrane
Does anyone know what the boundary condition for a free edge of a vibrating rectangular membrane would be?
The fixed condition is easy, but what about a free edge?
RE: Vibrating rectangular membrane
The bending moment and shear force vanish at the free end
peace
Fe
Wouldn't that be for a thin plate? I'm thinking of a very thin membrane, so there wouldn't be any moment or shear to begin with.
I don't think you can analyze stresses with membrane theory alone.
I am not 100% sure though.
peace
Fe
Maybe, membrane force in the direction normal to the free edge = 0
I don't think it would be a force boundary condition, I was thinking along the lines of maybe a gradient??
For the fixed edge displacement is 0 for sure. But if it's free...
Displacement gradient (strain) = 0 -> force (stress) = 0
The terminology that I have heard is that membrane is the 2-D equivalent of a string (the PE results from tension), while a thin plate is the 2-D equivalent of a beam (the PE results from bending).
Are you interested in a beam or a membrane?
The term "fixed" does not compute in my world for membrane, since it implies a moment applied to enforce zero slope... you can't do that for a membrane/string.
Correction in bold:
Are you interested in a plate or a membrane?
I mean membrane. Maybe I should have said clamped instead of fixed. So one of the edges could be held down, making displacement 0. What I don't know is what the condition would be for a free edge (not clamped)
Here's what I know about strings. There are two types of boundary conditions:
pinned:  displacement = 0
free: applied axial force =0
At first glance, it seems like we are missing something... don't we need two equations per side like we do on a beam? No, only one equation per side for string since it is a lower order differential equation than a beam.
I am guessing a membrane is a relatively straightforward extension of a string... but I'm not sure.
The free would probably be pretty uninteresting for a string... but at any rate the condition is that there is no applied tension or force at the boundary.
How long is piece of string?
To use your string analogy, the bc at a free end is that there is no force in the tensile direction.
So with a membrane the bc is that there is no stress normal to the free edge.
Is that enough?
Cheers
Greg Locock
New here? Try reading these, they might help FAQ731-376: Eng-Tips.com Forum Policies  http://eng-tips.com/market.cfm?
