LT2...What are the chances?
I was reviewing some of the rulemaking discussion for LT-2 in the Federal Register, but it was breaking my eyes. It seems that one assumption in the cost-benefit analysis was that only a small percentage of small filtered systems would fall in bins above 1. Does anyone recall how they made that assumption? I am looking at making proposals to systems that may or may not have to treat under the rule. One system apparently has GWUDI with an e coli count around 50 in the stream which supplies their well, and thus are monitoring for cryptosporium. What are their odds of falling in bins 2 through 4? What are the general parameters that would allow one to guess pending the testing results?
RE: LT2...What are the chances?
will that help?
For the small systems I work with, if they needed more treatement I would look at UV, but it looks like they will fall into bin 1.
Hydrae
I can post the letter if you need me to.
Hydrae
