Hi about M10, M11, M78 M79
Hi frds
I have few question about UGNx6 postprocessor, When I post 4th axis or 5th axis I cant see any M10, M11,M78&M79 those are (Table Unclamp, Table Clamp, Rotary Unclamp, Rotary Clamp). I attached a sample 5th axis part have a look.And help me to comeout with this problem... becoz I am new to postbuilder.
Thanks & Regards
Holy.Ghost
Your file's link is: http://fi les.engine ering.com/ getfile.as px?folder= 28998351-4 368-4842-b 20f-601f8c f5b46d& ;file=5th_ axis_sampl e_part.rar
Thanks & Regards
Holy.Ghost
RE: Hi about M10, M11, M78 M79
If you want to output the clamp codes automatically, you need to "turn it on" in NX.
You do this by using a machine control "start event" (OR you can edit the start events in the FIRST operation).
1. Create a new operation > choose "Mill Control"
2. select the "user defined events"
3. add the "clamp" command
4. Settings as follows; Status=active, clamp axis=auto, clamp status=on.
Now when you post, you will see the clamp commands!
Jay.
Thank you very much Jay. Now I can see All codes.
I have another question
That is I always like that all my programs must be in standard like
EG. PROGRAM..
T01
M06
T02
M11
M79
G54G90G40G80G00X0Y0B0A0
G43Z100.0H01
M01
M03S1200
M08
G00Z100.0M09
M05
G91G28Z0
M30
IS IT POSSIABLE TO CUSTOMIZE OUR POSTPROCESSOR AS ABOVE....
IF POSSIABLE CAN YOU GIVE ME AN IDEA WHICH PARAMETER TO BE CHANGED OR ADDEED.
You can change just about anything in the post.
You'll need to be a bit more specific about what you want changed.
Perhaps if you include some "before and after" code, I can more easily help you out!
Jay
Thax Jay and Bugie, I created Postprocessor as I wanted. Everything is fine, But I didnt see "work offsets (work co-ordinate system)" "G54,~G59" in output.
- Let me know where I need to create or asign this ...
or
- I need to select while creating MCS or ..... plz can you tell me where exactly I need to selct.
Thax & Regards
holyghost
