How to figure a continuous service rating
A small needle type valve has a pressure rating of 3500 psi and a temperature rating of 900 F but the manufacturer (who is no longer around) doesn't indicate if this is a continuous service rating. What testing must I do to assure myself the stated psi/temp will work in a continuous 3500-psi, 900 F application?
What's the ASME/ANSI Standard I should buy to check this out?
Thanks in advance for your time.
RE: How to figure a continuous service rating
I assume you have checked the maintenance manual and the valve list and found nothing.
The valve may have been supplied through a third party such as the turbine supplier in which case they may have a record.
athomas236
Fitz-
This really belongs in forum408: Valve engineering where you'll get a much better audience. I'd suggest you repost it there then hit the Red Flag button and ask for this thread to be removed.
jt
