Steel pipe piles hitting an early refusal. Any recommendations?
I am a structural engineer working on driving steel pipe piles for an oil sands treatment facilities. Based on the soils report and design drawings, the design embedment of most of the piles range from 20 m to 26 m. The pile top cut-off elev. is about 1.5 m above the final grade, so the total pile length would be 1.5 m longer than the design embedment. For additional info, each pile will support a steel column (no skid or concrete pile cap).
Most of the piles we have been driving met the design embedment, but there were several piles that hit early refusal. Some of them needed to be driven about 26 m deep but were actually driven 20-21 m. The rest of them are quite or way off of the design depth. They needed to be driven about 24 m but were actually driven only 7-8 m. Since we had more than 100 blow counts at the refusals, I wouldn't worry about the pile axial compression capacity, which was also confirmed by our geotechnical consultant. The concern is the piles tensile capacity. The design tensile capacity is way more than the actual capacities we will get from those piles.
Now we are trying to come up with ideas to fix this up. One solution we are discussing is to take them out, drill the holes down to 20 m or something, and put them back in the holes, and backfill it. I would like to perform additional borings around the area, but the client wouldn't accept it.
I am wondering if there are any better ideas out there. Any idea, opinion, and/or recommendation on this issue would be highly appreciated.
Thanks.
RE: Steel pipe piles hitting an early refusal. Any recommendations?
I would pre-drill through the probable hard lense, then drive to refusal.  I would not remove the piles already driven...just extra expense.  Another option is to use Augercast piles adjacent to the bad piles.
Thanks for your valuable recommendations!
Well, if the pattern of the probable hard lense was predictable, I would pre-drill down to wherever I am comfortable with, but it is not. Hence, the second option sounds better. One question in this option would be once Augercast piles are driven around the bad piles to compensate the loss in tensile capacity, do all of the piles need to be capped all together?
The Augercast piles are not driven...they are cast in place.  I would not tie a short pile on a hard lense to a longer pile adjacent to it.  Just cut it off and leave it.
Ron, thank you again for your input.
Yeah, that was my mistake. So basically what I will get from the Augercast piles is additional frictional resistance in either tension or compression due to the fact that the piles densify the soil around the main pile. Hope this is correct.
If the short pipe piles are open-ended, if the pile tips are not crushed, if the pipe pile diameter is sufficient, and if the economics work out; you could drill down through the short piles and install micropiles which could work for both tension and compression.
www.PeirceEngineering.com
hughits...that depends on whether your steel piles were displacement piles or not.  If open steel pipe or shoeless H piles, there's not much densification of surrounding soil, but if closed pipe or H-pile with a displacement shoe, then densification will occur...but that's not necessary for the Augercast pile.  If you have a reasonable soil profile, they will work either way.
PEinc's idea is good as well...it would be worth considering for open ended pipe.  You can also blow the end out of closed end pipe using a mandrel if you want to try his method.
Thank both of you! I am using open steel pipe piles, so I don't have to blow the end as Ron suggested. Micropile idea sounds good to me. I am not sure if the pile tips are crushed or not. The pile diameter is 508 mm, which I think large enough.
Thanks again!
hughits...yep, 508mm is large enough!
I know you stated that you have a geotech but just to play devil's advocate,  refusal does not necessarily mean design capacity.  You may have an unusual situation where the driving energy is being dissipated into the surrounding soil.  Driving formulae are actually quite complicated depending on soil.
VoD
That's true. Nobody knows what's in there and what's preventing us from reaching the design depth, which is the reason why I am seeking for solutions for this issue. Currently what we rely on are two things; more than 100 blow counts/25 cm at the refusals (we concluded that any further attempt to drive the piles could cause damage to them) and the confirmation of the geotechnical consultant that is working for us. He seems to be concerned about tensile capacity only as he is sure that the piles are getting enough compression capacity (actually end-bearing capacity).
Thanks for your opinions!
Another possibibilty is to load test the shorter piles to find the actual ultimate resistanc and drive some additional piles to give you sufficent tensile capacity. Usually compression is much higher than required tensile and thus drives the bus. Shorter piles may be okay. If you did any PDA testing during pile driving, you may be able to estimate tensile capacity from that.
Thanks for your answer! Actually I made a decision to do PDA on all of the piles in question. I didn't want to do anything further without knowing what capacities I need to get and I have currently. Then I will go from there. Thanks for your opinion that supports my decision. This is good!
Uplift resistance needs to consider both the frictional bond of the pile to the soil and the mass cone stability.  A short pile may test OK for friction but there may not be enough of a cone to prevent the pile from pulling up the soil with it.  Often, the required size of the cone mass dictates a longer pile that does the frictional bond.
I got your point. I understand that it's similar to deep-seated failure of a retaining wall conceptwise. I will have to have the geotechnical consultant check this failure cone, too. Thanks again for your valuable opinions.
If the cone of soil extends below the water table, you have a lighter, buoyant, soil weight which will increase the required size and depth of the cone.
PEinc...isn't that only valid in cohesive soils?
Why?  Any submerged soil is still buoyant.
No... to develop a tension cone requires cohesion...otherwise just friction on the pile wall.
Per FHWA's GEOTECHNICAL ENGINEERING CIRCULAR NO. 4
Ground Anchors and Anchored Systems, Report No. FHWA-IF-99-015, http://www.fhwa.dot.gov/engineering/geotech/pubs/if99015.pdf
5.9 TIEDOWN DESIGN
5.9.1 Introduction
Tiedowns refer to vertical or downward inclined ground anchors subjected to uplift forces.
Examples of tiedowns include foundation elements for structures subject to overturning or uplift
such as transmission towers and vertical anchors used to resist hydrostatic uplift forces in gravity
dams and underwater slabs. Tiedowns are designed to resist two possible failure mechanisms: (1)
individual anchor capacity to resist uplift pressures; and (2) overall stability of the ground mass
wherein the tiedown group geometry is sufficient to envelope a mass of ground to resist uplift forces
5.9.3 Uplift Capacity of Soil Tiedown Anchors
For tiedown anchors installed in soils, the failure mechanisms of cone breakout and interface shear
along the soil/grout interface are analyzed
. Like rock anchors, the cone breakout mechanism
dominates for shallow anchors whereas interface shear dominates for relatively deep anchors
. A
grouted soil anchor subjected to uplift behaves similarly to a small diameter drilled shaft subjected to
uplift.
5.9.4 Design of Tiedown Anchors to Resist Hydrostatic Uplift
Tiedowns may be used to provide resistance to uplift forces caused by hydrostatic pressures. A
notable use of tiedown anchors in the U.S. was to resist hydrostatic uplift of a depressed roadway
section as part of the Boston Central Artery project (see Druss, 1994). The primary issues related to
the use of anchors for such tiedown applications are: (1) general stability of the enclosed ground
mass
; (2) changes in anchor loads resulting from movement (i.e., surface heave, consolidation
settlements, creep deformations) in the enclosed ground mass; and (3) corrosion protection and
watertightness of the ground anchor. Corrosion protection and water tightness are discussed in
chapter 6.
General stability of a structure subjected to uplift is shown in figure 54. The system is in equilibrium
when U=W1+W2, where W1 and W2 are total weights of the structure and the enclosed ground,
respectively, and U is the total uplift resulting from the uplift pressure γwh. The geometry of the soil
mass assumed to be mobilized at failure may be evaluated as shown in figure 54. Frictional
resistance that may develop between the ground and the sidewalls of the structure may be
conservatively neglected.
Although driven piles are not normally considered to be tiedown anchors, when called upon to be such, the same mechanisms apply.  Since the original poster's piles are short, mass stability should be a design cansideration.  It will probably control the length of the piles.
You have come accross a very difficult problem.
I have been wrestling with the same problem for more than a year on a bridge I am working on.
The first thing I would try is to relief drill within the pile to remove whatever plug has built up on the inside.  Then try to redrive the pile and see how much further you get.  You will learn a lot of usefull information from this.  When you do the redrive make sure you have the PDA to monitor the driving.  In all likelyhood you will not be able to make this work because your piles are probably damaged at the tips, and may be bent along the shafts as well.
I have done many PDA and also static tests on the piles with all kinds of results.  The most difficult issue with the PDA testing is to sort our the frictional component along the outside of your shaft from everything else.  The problem with PDA is that there are only non unique solutions.  You have too many variables to deal with.  In the end it will give you some good results especially for overall capacity, but you really have to understand its limitations to know what to make of the friction results.
The static test did show very high capacity when you have a damaged or "hooked pile".
What type of soil are you in?  Is it mostly sands, or is it all cohesive?  Have you looked or measured how much plugging you are getting on the piles you have driven?  Have you compared the plugging on the ones driven to design depth with the ones driven short?
You should probably count on very little to zero tension capcity for piles that are as short as the ones you have stated (7-8 m).  How much tension do you need to achieve?
The difficulty with open ended pipe piles is that you are driving from a condition with the only resistance being along surface of the pile, to one where as you increase the plug then you are increasingly driving a displacement pile.  As the pile plugs it gets more difficult for objects such as cobbles to be pushed out of the way.  The relief drilling does allow some progress in cobble zones, but it is limited.
What I have resorted to is preaugering ahead of the pile driving, and leaving all the material in the hole, then driving the pipe piles as far as I can.  If they stop early I try the relief drilling, and usually can get them another 5 to 10 feet deeper (but I am in a heavy cobble zone).
If I still can't reach my tension needs then I drive some replacemnt H pile next to my CISS piles to supplement the tension capacity.  This is the cheapest way to keep the job moving.  The H pile drive better in the cobbly zones.
I stop all pile driving at 50 blows per foot to limit damage.  I learned this from the PDA testing.  During the earlier stages of work we were driving at much higher blowcounts, but found that damage started to happen as noticed by the PDA between 55 to 60 blows (on a 24"x5/8" PP with a D46-32 Hammer).
"I stop all pile driving at 50 blows per foot to limit damage."
Only 50 bpf?  FYI, PennDOT wants 20 blows per inch as refusal!
PEinc.
Unfortunately 240 blows per foot equivalent was tearing up the pile to much, it wasn't doing any good.
Check out these pictures of some we extracted.
The main reason to stop is to be able to work inside the pile easier since we are doing CISS piles.  Otherwise I might not care as much about the damage.
After a sequence of stopping driving at 50 blows, and cleaning out the interior, then redriving, the pile are getting well into any cobbly zones.  I have tried a second round of relief drilling and driving but they did not advance more than a foot after that, so the extra cost was not worth it, and it gave me some confidence that I would have some end bearing.
Everyone says 240 bpf is too much but that's what PennDOT wants - and gets.  They also make you design the piles for A36 36 ksi even though the steel is A572 50 ksi.  It's only money!
Mostly sandy soil with a little bit of silt and clay here and there. Checked the soil plug elevations, but their pattern doesn't seem to be correlated with the driviability. The required tension capacities vary between 500 and 1500 kN.
We decided to do PDA on those piles hitting early refusal; we actually did on two of them. The results were very encouraging. The actual compresison and tension capacities are 7-8 times greater than the ones we obtained from the capacity vs. depth design chart provided by the soils consultant. Even with the short embedments, they are okay.
By the way, we got a little more than 100 blow counts per 12 cm on those piles and stopped driving as instructed by the soils consultant. I believe some or most of them must have been damaged at their tips, but we got enough capacities and moved on.
For some of them for wich we can't get enough capacities, we are planning to drive some compensation piles around them. Hammper impact weight (piston) is 4600 kg.
Hughits
I would be skeptical of the values for friction (in tension) being that much higher than what you get from the capacity vs depth formulas.  Using very conservative delta and K values in the API formula vs using more generous ones I would only expect a difference in possible capacity ranges of about 3 for pile that are only 7-8 meters in sandy soils.  [Say API using K at 0.8 for PP, and Delta of 15 deg, you would get about 60 kips (about 270kN) at 25 feet (7.6m) depending on the overburden (120pcf) vs. about 155 (about 690kN) if delta was 35 deg.]
I would expect that you had much higher that predicted capacity for the compression due to the end bearing.  The hard part with the PDA is distinguishing the frictional component from the end bearing component.  I have had several PhD's who do the PDA stuff doing many tests for me and lots of CAPWAP and they have come to the conclusion that it is a very hard thing to figure.  It could be that high but I would not trust it from the PDA stuff only with the static tests.
You have a big hammer so you are definetly getting some good compression values if you are only going 12 cm for 100 blows.
For specifically the pile in quesiton, I wouldn't worry about it too much at this point. The design loads for tension and compression are 960 kN and 1170 kN, respectively. The capacities we obtained from the PDA test are 4100 kN and 5200 kN for tension and compression, respectively. I didn't know that it was hard to breakdown the tension and end bearing component from the total capacity. The numbers we got - 4100 kN - is about 4.3 times great than the required tension capacity though, which I thought would be okay.
Only needing 215 Kips for tension should give you a good bit of leeway for piles that test that high for total capacity.
You design load is very close to what I have on my project.  It is very interesting for me to see what someone else is getting in a very similar situation.  I am driving 24 inch PP (610 mm)about 46-58 feet (14-17.5 meters) to achieve greater than 200 kips (890 kN) tension and 400 (1780 kN) - 600 kips (2670 kN) compression.  A good bit of my capacity is comming from end bearing of a plugged pile.  Some of my piles are refusing earlier slighly past 30 feet (about 10 m).  These ones I generally have to supplement with HP 14x117's.
We did a static test on several of the piles that were damaged and was able to pull over 500+ kips (2225+ kN).  The shortest pile tested was about 35 feet long (about 11 m).  We came to the conclusion that the damaged section was catching or hooked and therefore was providing some additional capacity above what one would expect from friction alone.
We also have done PDA testing on about 36 piles with lots of different results as I said before (from about 480 to 1440+ kips (2130-6400+ kN), by CAPWAP, total capacity).  Results vary a bit more by Case method.
On average I would say about 50 percent is friction and the rest in end bearing.  Some times friction is as low as 10 to 20 percent.
Is there any bitumen in your sand deposit?  Is that contributing any to your friction values?  Just curious because you said it was being done for a oil sand process facility.  Just want to know how close the geology is to what I am dealing with.  I am in a riverbed with about 5 feet (2 m) of sandy fill, then about 30 to 40 (9 - 12 m) feet of younger alluvium, and about 30 feet down is lots of cobbles, and boulders and heavy gravel deposits on occasion.  About 45 to 50 feet (14-16 m) I get to a very dense older alluvium which is my target for reliable end bearing.
It would be interesting (and important) to know if the toes of the piles are damaged, as already has been mentioned this could be the problem. Have the toes of the piles been reinforced with additional plate?
What about using a vibro to see if it can better deal with the soil conditions.
