Using Hide/Show
Using Hide/Show
Using Hide/Show
I have Catia V5.19
I have a 38 pc assy (cat product).
can I hide/show....
all partbodys with 1 button click?
all wireframe/sketch with 1 button click?
all dimensions with 1 button click?
all fta/gdt with 1 button click?
I have 1 customer that insist we use catia for all their work. This is my 1 time a year in Catia, it is very frustrating that I can't fly thru it.
Thanks in advance.......
RE: Using Hide/Show
Main Menu\Tools\"Show All"
Main Menu\Tools\"Hide All"
RE: Using Hide/Show
You can also use CNTRL + F or Edit--> Search.  Setup your 1 button click wish list in the favorites.  To do this, make a valid search then hit the "Add to Favorites" tab at the end of the Query line.  The next time you need to hide/show stuff
Cntrl + F, Favorites tab, select your custom item, Hide/show.
Derek
RE: Using Hide/Show
I start Catia P1 V5R19.
I then go ....file - open - xxxxxx.catproduct
The assy is on the screen.
Across the top  my choices are.....
start,file,edit,view,insert,tools,analyze,window,help
Under "tools" there is no....show all or hide all.
Under "view" there is a hide/show.....but does nothing I can see.
RE: Using Hide/Show
Thanks for helping.....
RE: Using Hide/Show
Maybe the method I mentioned is only available in CATParts? I'll have to check tomorrow.
RE: Using Hide/Show
Yes, Tools Hide/Show is only available for CATPart files, but not for assemblies.
We had our IT guys write a macro for us. One macro that hides everything in one step. We also started to teach our users to hide all the construction geometry before saving their parts, but I guess that's not an option for you.
Derek's suggestion is easy to setup and quick to use.
