Spiral Bevel gear in NX
Can anybody give a good reference to read that will help me create a spiral bevel pinion gear in NX6?
I understand the cones that are associated to the OD and root diameter of the gear, but I do not understand the path that the sidewalls of each tooth follow as they are related to the mean spiral angle.
RE: Spiral Bevel gear in NX
Take a look at this helical gear by all means. It was created partly in association with an earlier question on this forum. Among other things you should be able to deduce a reasonable construction method from the file. Hopefully it also helps with you're gear design question.
Best Regards
Hudson
www.jamb.com.au
Nil Desperandum illegitimi non carborundum
