cart on plywood
cart on plywood
I am trying to span a distance of 48 inchs with plywood to run a push cart on to bring some heavy equipment to an area. I am looking to find what forces this plywood can handle. any suggestions on doing this?
RE: cart on plywood
Plywood is engineered wood. Consequently, orientation and usage is important.
RE: cart on plywood
http://w
Mike McCann
MMC Engineering
Motto: KISS
Motivation: Don't ask
RE: cart on plywood
Spanning 4' and using ¾" Class 1 Plyform, Fb=1500± psi, the maximum load you'd want to place on the plyform would be around 20 psf which isn't much if you are moving equipment over it.
You would most likely need joists or some other support under the plywood and space it at whatever your load requires.
RE: cart on plywood
If you find that the panel thickness is not adequate (say a 1.25" thickness), considered field laminating an additional layer using adhesive, nails and screws.
Remember that you can perform an analysis using first principals knowing the thicknesses and number of plys.
RE: cart on plywood
