Using Thermography to carry out energy audit
As I know, thermography can be used as a tool to carry out energy audit of a building. However, it is very difficult to find a suitable methodology or guildline to do so. Is there any guildline or standard that tells how to carry out energy audit? If no, any methods? Also, how to interprete the result? Please advise.
RE: Using Thermography to carry out energy audit
Given the variations of materials and emissivities, it can still be quite tricky. I'd assume that you'd be able to get gross indications of energy loss, but determination energy flux variations of less than 30% are probably the best that one could do, unless one had lots of moey for calibration and characterization of materials, paints, etc.
TTFN
With regard to standards, there are two main standards that can be used for frame buildings:
1. ASTM C-1060: Standard practice for Thermographic Inspection of insulation Installations in Envelope Cavities of Frame Buildings
2. ISO 6781 Thermal insulation, qualitative detection of thermal irregularities in building envelopes, Infrared Method
A further related standard is:
ASTM C-1046 Standard practice for in-situ measurement of heat flux and temperature on building envelope components
For concrete buildings the American Concrete Institute (ACI) Design Standard 530 incorporates an excellent procedure that include infrared testing.
A great deal has been published with regard to building inspections over the years. I suggest you turn to either the Proceedings of Thermosense, published by SPIE (www.spie.org) or Thermal Solutions (www.thermal-solutions.org).
If I can be of further assistance, please feel free to contact me.
Thermally yours,
John Snell
jsnell@snellinfrared.com
http://www.snellinfrared.com
http://www.thermal-solutions.org
