need a little help
need a little help
For a project we have to create a belt a sitation where a belt length should control the path the belt. In one condition should run on top of the belt pulley in the other condition it should run in the buttom - look attached pic *nx4.
thx in ad
thx in ad
RE: need a little help
What you don't appear to be accounting for is the thickness of the belt when it runs on the opposite side of the jockey pulley as shown in the image. Nor have you explained what conditions dictate when it swaps sides. Frankly I doubt that it can be done with a single sketch. I suspect that the programmers of the software have gone to a lot of trouble trying to optimise an algorithm that doesn't swap sides accidentally. Getting the system to do so on purpose seems counter intuitive to me.
Best Regards
Hudson
www.jamb.com.au
Nil Desperandum illegitimi non carborundum
you are right,
the attached pic should help to clear up the problem.-
its a thumbsketch.
there is no need to use a single sketch,
the wheels are from wave links - I only want to control the belt path from expressions /condition - how to set up control this requirement.
thx
Best Regards
Hudson
www.jamb.com.au
it works
