NX6 Face Selection problem
Hello. I've a part model contains of faces. But I cannot select face that I want. Are there an option in NX6 about it? Did you faced a problem like it?
RE: NX6 Face Selection problem
Does it look correct when shaded?
It could be a sheet instead of a solid.
Thank you for your response. There's no solid in my model. Faces are seen as body in tree. I place my mouse a face that I want to select. While I can select some of faces, the others can't been select
Unblank everything.
Make sure all the layers are selectable.
I have had some models (done overseas "east") where they used "visible in view" in the model - make sure there is none of that in your model.
Format > visible in view > reset to global  ... you may need to do that for all the canned model views
